9 years agoQuartus Prime 16.1: Cannot Edit PCIe BAR widths!!
I am using Quartus Prime 16.1 on Windows, targeting Arria 10. Although I also encountered the problem on the Linux version. For some reason when I add the "Hard IP for PCI Express" I cannot edit the ...
8 years agoI ran into this. The fix is that you need to go into Address Mapping and set the addresses first.
For example, for me bar[4] goes to two instances. In address mapping, I set the addresses as follows: instance 1: 0x0000_0000_0000_0000-0x0000_0000_0000_001F instance 2: 0x0000_0000_0000_8000-0x0000_0000_0000_801F Then I went back into the HIP instantiation, and toggled between IO Bar and 64-bit prefetchable BAR. The 64-bit prefetchable BAR address width now changed from 5 to 16. (bit 15 is set in the address... it doubles the address space by setting bit 16).
