10 years agoQuartus Prime 16.0 stops compiling before fitter runs
So, I made the choice (mistake?) of upgrading my Quartus Prime Pro version 15.1 to Quartus Prime Pro version 16.0. I ran the IP updater on my project that I am upgrading from 15.1 to 16.0 and ever...
10 years agoI have exactly the same problem along with some other issues that popped up when I moved from 15.1.1 to 16.0.0... Analysis & Synthesis (and Analysis & Elaboration) run fine but after that the compile just stops... If I try to force a Fitter run, the spinner will spin for a minute or two (without incrementing the clock, bottom right) and then just stop.. No messages, not nothing...
I have sent an email to my FAE's to see if it is possibly a licensing issue... I'm running an Arria 10AX048E3F29E2SG with two 32 bit banks of DDR3 and a couple of transceivers... The Quartus Prime experience for me so far has been a beating from the very start... Never could get a pinout unless I used the BluePrint tool...
