Quartus pauses between A&S, Fitter and Assembler
Hey,
recently quartus seems to behave quite strange for my project. All of a sudden compiling takes much more time and i have the feeling that quartus pauses between the Analysis & Synthesis, Fitter and the Assembler steps. Before my project was doing analysis and synthesis in about 5 minutes - now i also get the message that A&S has finished after 5 minutes but it takes at least another 5-6 minutes until the fitting starts. The same thing happens after the fitting and the assembler. Has anyone encountered similar problems? I am using Quartus 15.1 cheers7 Replies
Had someone else debug that it was due to something going wrong with TalkBack, so you might want to turn it off. Tools -> Options -> Internet -> Talkback. Please post if that works.
I think that was the problem... seems to work just fine now! Thanks a lot.
However I need the talkback as i want to use the signaltap features :/ Maybe setting up the talkback again could help.. - Altera_Forum
Did you try turning TalkBack on? There were some internet problems at Altera yesterday that have been resolved, and I'm curious if they are related?
I still have the same problems when i turn on the talkback:
A&S done after 5 mins Starting Fitter after 11 mins - Altera_Forum
Argh. I heard the TalkBack server crashed and is being fixed with high priority, but don't have an ETA. Thanks for checking.
We had the same problem with the increased compile times and need for signal tap. We were able leave talkback enabled but added a rule in our hosts file that rerouted requests to talkback2.altera.com to the local host, we used 127.0.0.2. This allowed the request to timeout much more quickly and brought our compile times back down to earth.
I just heard the TalkBack issue has been fixed.
