9 years ago[Quartus] Organize project files in folders
Is it possible to organize the project files in folders? For instance if a folder will have the module itself, a top module which contains the module and a testbench script. and in quartus I wan...
9 years ago --- Quote Start --- You can organize your files in whatever folder structure you want, but as far as I know Quartus will always show the files flat in the "Files" view of the Project Navigator. However, did you notice that there's a "Hierarchy" view in the Project Navigator? As soon as you ran synthesis (or at least analysis & elaboration), it'll show you a hierarchical view of the source files. I know this is not exactly what you asked for, but the closes Quartus feature I know of. --- Quote End --- The hierarchy view is not of the source files; it's the hierarchical view of the design entities and their instantiations after analysis & elaboration. In the Files view of the project navigator, you can see all the files used by the compiler, but they are not organized hierarchically.
