16 years agoTwo suggestions:
1 - Obviously I can't see your design but if you simulate your circuit, I think you'll see that it does work as you want it to. 2 - Read the section that begins on page 6-46 of the following document: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf Generally, internal tri-states are a discouraged design practice. Jake
