AhmadQ's avatar
AhmadQ
4 years ago
Quartus newest version significantly slower than version 9
Hello,I have recently started learning HDL,so my university tutor wants us to use quartus 2 version 9,but i wanted to use the newer version so in installed it from Intel's website.When i ran the attached code it took 1 minute and a few seconds to compile the attched code,however,when i compiled the same code on Quartus 2 version 9 it only took around 7 seconds.Is this massive difference normal?
Also I noticed in the newer version a lot more processing have been done(over a 100) unlike the older version(around 50 processing).
  • sstrell's avatar
    sstrell
    What is your target device? And are you referring to a full compilation or just performing analysis & elaboration to verify no errors in the code and set up the project hierarchy?
    • AhmadQ's avatar
      AhmadQ
      Well, we're using the program to simulate basic circuits, not applying them to a specific device,so I don't have a specific device as I am not working with actual hardware yet. But in quartus version 9 i can see it's set to EP2C20f484C7 in the cyclone II family.
  • sstrell's avatar
    sstrell
    You can't create a project in Quartus without targeting a specific device, so I'm confused by your first statement, unless you're saying you chose the device family and the option to let Quartus automatically choose a device from that family for you (in the New Project Wizard and Device settings).
    But then, are you saying you are only simulating designs and not compiling them? "Compile" means you are synthesizing the designs into logic primitives which then get placed in specific locations in hardware.
  • VenT_Altera's avatar
    VenT_Altera
    Could you provide your project file (QPF file)? So that I can check which family and device are you using.
    For your information, I run your Verilog code in the latest Quartus using Cyclone V (5CGXFC7C7F23C8), the compilation time is about 1 min.
    So, your compilation time should be in the normal range. No issues here.
    Ven Ting
    VenT_Altera
    Hi AhmadQ,
    We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
    Thank you.
    Ven Ting
