18 years agoI would give my partner the VHDL.
But if you're sure you want what you're asking for then try... quartus_map (project) quartus_cdb --vqm=(project).vqm (project) put the VHDL file somewhere safe, use the VQM source instead. It may well not work. The SOPC builder most likely knows things about the component like the bus port interface, parameters, etc. which will not hold on a synthesis cell netlist.
