RIvy
7 years agoQuartus ModelSim Memory allocation failure
Windows 10 with 25GB available RAM and plenty of swap space. My design is SIGNIFICANTLY smaller than the 10K executable code line limit for the Intel-FPGA ModelSim Starter edition unless some ALTCLK...
Abe
7 years agoLooks like the issue is with the WLF simulation file being in use by another user/program. This is the warning from ModelSim before it crashes trying to allocate more memory.
# ** Warning: (vsim-WLF-5000) WLF file currently in use: vsim.wlf
# File in use by: Richa Hostname: ECS-ZBOOK-17-G4 ProcessID: 50584
# Attempting to use alternate WLF file "./wlftykv95n".
# ** Warning: (vsim-WLF-5001) Could not open WLF file: vsim.wlf
# Using alternate file: ./wlftykv95n
I suggest you check if any other modelsim processes are in use via the Task Manager and kill it. Close all Quartus/ModelSim tools and kill all vsim/vlog processes that are running via Task Manager. Then re-open the project and try running the simulation.
