quartus_map generate symbol functionality does not support BDF file as input
quartus_map fails to generate symbol for BDF file
quartus_map --generate_symbol=file.bdf
Error (12073): Can't create symbol or include file -- file file.bdf is a BDF or compatible fileI think this should be supported since from Quartus I can open BDF file and do File > Create/Update > Create Symbol Files for Current File.
I found that using quartus_map I can convert BDF file to HDL file and than create symbol file for HDL file using quartus_map. But in that case resulted symbol file is slightly different than one created from UI. To be more precise I get other pins order.
So I think quartus_map should allow me to convert BDF file to symbol file directly to get consistent results with Quartus UI.
- Vicky1
I tried to replicate the issue & realized the same behavior about .bdf file if as a input but I couldn`t find any difference in symbol file.
Vikas Jathar
- Vicky1
Vikas Jathar
- VVavr1
I think that the fact that quartus_map does not accept .bdf as input is already a problem. Because documentation everywhere says it should accept. And UI allows to do this.
- Vicky1
Hi VVavr1,
Yes, it`s a bug & I will try to report it.
Vikas Jathar
