13 years agoHi,
I encoutered internal Q12 crash relating to a missing .cdf file of the TSE IP. Altera support did not find the reason causing it. Finally, after many different tries (removal of db and internal_db directories and other stuffs), the solution was to delete the TSE in SOPC Builder and regenerate the same one. Good luck.
