KAshc's avatar
KAshc
8 years ago
Quartus LPM_Compare Constant
I am migrating schematic designs from Quartus 9 MAX-II to Quartus 16 MAX-10. I am having to re-create (instantiate) all my LPM modules. On the LPM_Compare I used to have 1 input as constant. I see the option in the new Quartus 16 for this but where do I enter what the constant is? It was intuitive on the old Quartus 9 software.
  • KAshc's avatar
    KAshc
    Yes I did. Using the IP catalog brings up the wizard like I was used to in Quartus 9.
    Keith
  • Vicky1's avatar
    Vicky1
    Check it under"General 2" Tab.
    find attached screen shot.
    Best Regards
    Vikas Jathar
  • KAshc's avatar
    KAshc
    Quartus 16 doesn't have the wizard, or at least it doesn't seem to run. The only way I can change anything is to right>click and then edit the properties.
    Is the wizard supposed to run on Quartus 16?
  • KAshc's avatar
    KAshc
    UPdate. I am downloading and installing 14.0. I read where the wizard was discontinued with 14.1 and 14.0 will support the MAX-10.....
    Wish me luck!!!!!
  • KAshc's avatar
    KAshc
    ALL, New Update. by using the IP Catalog, instead of doing a double-click to add library modules, a wizard is utilized. Went back to Quartus 16 and now instantiate modules a lot easier now, plus I don't get those big obnoxious square graphic symbols.
  • Vicky1's avatar
    Vicky1
    Are you able to use 1 input as a constant using IP Catalog in Q16?
    Let me know if you need any further assistance.
    Best Regards
    Vikas Jathar
