Quartus Lite 17.1 crash sitting fit stage on centos 7
I get the following error during the fit stage when trying to generate a .sof:
Info (170194): Fitter routing operations ending: elapsed time is 00:00:07I
InternalError: Sub-system: CUT, File: /quartus/db/cut/cut_lcell_util.cpp, Line: 7104
Error in merging. Locked bit differs
Stack Trace:
0x6c809f: CUT_LCELL_UTIL::get_stratixv_assembler_lutmask(CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*) + 0xc8f (db_cut)
0x174f26: U2B_TRANSLATOR_AV_LAB_ALM::convert_alm_attributes(U2B_BCM_CONTENT*, CDB_ATOM_GENERIC*, U2B_ATOM_CONTENT*, U2B_CONFIG_SV_ALE*, U2B_CONFIG_SV_LAB*, int) + 0x1c6 (db_u2b)
0x173e5e: U2B_TRANSLATOR_AV_LAB::convert(U2B_ATOM_CONTENT*, U2B_CONFIG*) + 0x426 (db_u2b)
0x6a1f3: FSV_U2B_POSTFIT::check_u2b_configs_for_conflicts() + 0x663 (fitter_fsv)
0x6e494: FSV_U2B_POSTFIT::work() + 0xc4 (fitter_fsv)
0x6cf166: vpr_qi_u2b_postfit_work + 0xb6 (fitter_vpr20kmain)
0x82b02a: aa_flow_finalize + 0x7a (fitter_vpr20kmain)
0x835e32: aa_flow_fit + 0x82 (fitter_vpr20kmain)
0x6e2c64: VPR_QI_FACADE::vpr_qi_main() + 0x24 (fitter_vpr20kmain)
0x6853e: fitapi_run_vpr + 0x5e (fitter_fitapi)
0x47041: FSV_EXPERT_BASE::run_vpr() const + 0xc1 (fitter_fsv)
0x47582: FSV_EXPERT_BASE::place_and_route() const + 0xc2 (fitter_fsv)
0x49c54: FSV_EXPERT_BASE::invoke_fitter() const + 0xd34 (fitter_fsv)
0x4593b: fsv_execute + 0x41b (fitter_fsv)
0x2457e: fmain_start(CMP_FACADE*) + 0x4ae (fitter_fmain)
0x1f826: qfit_execute_fit(QCU_FRAMEWORK*, QFIT_FRAMEWORK*) + 0x1d6 (comp_qfit_legacy_flow)
0x1bda2: QFIT_FRAMEWORK::execute() + 0x282 (comp_qfit_legacy_flow)
0x23568: qfit_legacy_flow_run_legacy_fitter_flow + 0x218 (comp_qfit_legacy_flow)
0x4d671: TclInvokeStringCommand + 0x81 (tcl8.6)
0x51ec7: TclNRRunCallbacks + 0x47 (tcl8.6)
0x536e7: TclEvalEx + 0x947 (tcl8.6)
0xfb366: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
0xfb47e: Tcl_EvalFile + 0x2e (tcl8.6)
0x11ebc: qexe_evaluate_tcl_script(std::string const&) + 0x382 (comp_qexe)
0x18dcf: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x597 (comp_qexe)
0x19d7b: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x57e (comp_qexe)
0x3e06a: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x1065 (comp_qcu)
0x1c586: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6b3 (comp_qexe)
0x3b75: qfit2_main(int, char const**) + 0xc5 (quartus_fit)
0x40720: msg_main_thread(void*) + 0x10 (ccl_msg)
0x602c: thr_final_wrapper + 0xc (ccl_thr)
0x407df: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
0xa559: mem_thread_wrapper(void* (*)(void*), void*) + 0x99 (ccl_mem)
0x8f92: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x63f2: thr_thread_wrapper + 0x15 (ccl_thr)
0x427e2: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa3 (ccl_msg)
0x22555: __libc_start_main + 0xf5 (c.so.6)
End-trace
1:04.20
Can I please get some assistance with this
- geon_bluquette
I replicated this problem with the attached project. Opening the project and trying to compile results in the same error.
- SyafieqS
Hi Jerry,
Is possible if you could provide us your design file for me to replicate the issue? You can attach it via private message/email feature there.
- jdarko
Hi @SyafieqS, my company works with @geon_bluquette and he was able to replicate the issue on his end. Can you please try his attached project. His attached project should be exactly what I tried.
- jdarko
@SyafieqS in the project that @geon_bluquette posted. I forgot there are some environment variables that I told him to set that I need to get rid of (I have a better way of doing it now) that causes some issues when you try to open that project.
I'll fix it and attach the project
