JuhanR's avatar
JuhanR
4 years ago
Quartus license count (build server)
Hi!
The question is mainly how many Quartus floating license seats would be required for the following use case.
We'd lice to have an engineer working with Quartus Prime on a laptop. If the design is complete, we'd like to upload the project to a faster computer (a build server), to build it faster there.
Does this require the license for both the engineer's laptop and the server? Can the engineer continue work on the laptop, or would the license have to be released for the server during the build process?
Many thanks!
  • AR_A_Intel's avatar
    AR_A_Intel
    Hi
    Welcome to Intel forum. May we know, is the floating license.dat file located in the (a build server) and you wanted to build project using this server + laptop?
    • JuhanR's avatar
      JuhanR
      Hello!
      Yes, the license file would be located in the build server.
      The idea was, that the project would be designed on the laptop, pushed to the server, most probably using git or SCP and built on the server. Mostly the builds would happen on the server, as it would be faster there, but maybe sometimes on the laptop as well.
      Thanks!
    AR_A_Intel
    Just dropping by to inform that we have yet to receive feedback from our support team regarding this issue. I will let you know as soon as I received an update from them. Thanks.
    AR_A_Intel
    Hi
    Upon checking with teammate, the require of license based on your requirement usage is 1 floating license and 2 seats
    AR_A_Intel
    We have not heard from you and I hope that my last note clears up this matter and it can now be move forward. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
