Quartus jtagd fails and unable to program MAX10 under Linux (18.1.0.625)
I am having a problem programing MAX10 devices under Linux. It used to work fine but I think some software updates have changed things (kernels?). I am running Fedora29 (although I have the same issu...
May I know if you have install Quartus or Quartus Programmer into your system? If yes, you should be able to find the driver under "<installation folder>/quartus/drivers/wdrvr/"
