17 years agoYes, I'm able to use it again. If I don't follow this procedure, if I just try to disconnect/reconnect the USB Blaster inside VirtualBox's Devices menu to try to get the VM to detect it again it doesn't work and VB throws some sort of error dialog related to USB. After that, I must restart the whole computer to get it to stop throwing that dialog. This is on a 32bit Vista SP1 host. On Vista 64bit I get a BSOD when I try USB.
