17 years agoyes, you can use the command-line programmer under linux without a quartus license. I'm using this to do the reverse of you, running the nios II IDE in a linux guest on a vista host. USB connection is working fine for me inside virtualbox. (in fact if windows sees and installs the driver, it's most probably your quartus settings that are off)
