15 years agoFinally, the Design instance name ('inst_selector' for example) to use in the edit test bench settings, is the name given for the instance of the component in the test bench files :
inst_selector : selector PORT MAP (A, B, Sel, S); If this name of instance change, the name in the settings muts change and could be not linked to the filename. EON
