15 years ago --- Quote Start --- Hello, I'm new with the ModelSim-Altera (i' known well Max+Plus II and the embedded version of simulation in the previous version of Quartus). I have readed Quartus Handbook and Help, lot of threads in the Forum but I did’nt found the answer. So I post this one. I’ve reduced my problem to the smallest ones to simulate one selector (selector.vhd). After the proposed modification in the Assignments Settings menu (Format for output netlist è vhdl, Map illegal HDL character è on, Compile test bench è T1 for the use of the benches file : “selector_test.vhd”. The EDA Tool settings for simulation are turned on ModelSim-Altera, with VHDL format. I’ve no problem with the RTL simulation, but some ones with the gate level ones.Modelsim (ModelSim Altera starter edition 6.5e) write in the transcript aera : # Loading instances from selector_vhd.sdo # ** Error: (vsim-SDF-3250) selector_vhd.sdo(0): Failed to find INSTANCE '/selector'. # ** Error: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s). # ** Error: (vsim-SDF-3250) selector_vhd.sdo(0): Failed to find INSTANCE '/selector'. # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./selector_run_msim_gate_vhdl.do PAUSED at line 12 What i forgot in the settings of Quartus II to use this new EDA-Tools (for me !) Thanks and best regards EON --- Quote End --- Hi, Quartus generates two files for the modelsim simulation. 1. <toplevel_name>_vhd.sdo ( this file contains the timing information) 2. <toplevel_name>.vho ( this file contains your design gatelevel) You need both file files for the simulation. I assume you forgot to include the <toplevel_name>.vho file. Kind regards GPK
