9 years agoQuartus II version 13 doesn´t generate pof or jam files... What to do?
Hi! I need to program (https://www.alteraforum.com/forum/#) some epm3032 (https://www.alteraforum.com/forum/#) cplds (https://www.alteraforum.com/forum/#). The bdf file was generated (https:/...
9 years agoEven though it doesn't generate .pof or .jam, it should generate .sof. You can then convert the .sof to the correct file format using the convert programming files option (which I think is in the Quartus File menu).
