18 years agoQuartus-II v7.2 incompatible with 'qrsh'?
Has anyone run into problems running the Quartus-II v7.2 command-line executables under the qrsh/qsub environment in Linux? I'm experiencing some problems right now: 1. First, I do "qrsh -l amd64=0 -cwd -l arch=glinux" to log into one of the machines in the server pool 2. Then, I run "quartus_sh -t some_script.tcl", which results in the following error: Tcl_InitNotifier: unable to start notifier thread Abort (core dumped) Does anyone know what's causing this error, and if there's a workaround? Thanks, Andy1 Reply
Sorry for digging out so old thread, but I encountered the same problem today and it's the only place in the Internet where the same question has been asked. Seems like the issue isn't related to Quartus version - I'm trying to qsub with Quartus-II 14.1 and I get the same error: Tcl_InitNotifier: unable to start notifier thread Abort (core dumped) I wonder if anyone has already come up with some solution for it? Thanks, Bartek edit: I managed to successfully run the job by adding -h_stack option for qsub (e.g. qsub -h_stack 1.000G job.sh). Hope it will will help someone in the future.
