16 years ago
quartus II tcl script problems
I am new to tcl scripting in Quartus II.
My task is to compile a project using a tcl script and then use another tcl script to change the directory and again compile a project using a tcl script in the new directory.
To compile the project the script is :
set project_name fulladder_new
project_new -overwrite $project_name# project_open fulladder
source fulladder.qsf
load_package flow
execute_flow -compile
project_close
To change the directory the script is:
set dirname D:/tcl_test
set sysdir $dirname
cd $dirname
I am using a main tcl script to source these two scripts.
source compile_script.tcl
source change_dir_script.tcl
However at the end of running the main script as
quartus_sh -t main.tcl
The directory doesnt change.
However if I run individual scripts, both of them work.
Can anyone suggest any way to fix this problem
    I would suggest using a single script with relative paths to both directories where your projects reside.
    Thanks for the reply.
    But the project requirements is such that I need individual scripts for all the sub-tasks.
    That is why I need to have the structure that I have declared.
    Ok. I suppose the problem is that the path changes in change_dir_script, but remains the old one when returning to the top script. I would suggest one of the following:
    1. Change the dir in the top script
    set sysdir $dirname
    cd $dirname
    2. Use relative paths in the compile scripts, referring to the initial dir where the top script is invoked.
