In the 'Node finder' the signal tmp_test only appears when filter is set to design entry. It doesn't appear in post-compilation. tmp_test is sourced from an unsigned and no output depends on it. This is the VHDL code :
ARCHITECTURE PCM3006_architecture OF PCM3006 IS
SIGNAL NEW_COUNT, COUNT : UNSIGNED (7 DOWNTO 0);
SIGNAL TMP_TEST : STD_LOGIC_VECTOR (7 DOWNTO 0);
BEGIN
NEW_COUNT <= (COUNT+1)MOD 256;
TMP_TEST <= STD_LOGIC_VECTOR(COUNT);
SYNC : PROCESS (CLK)
BEGIN
IF (CLK'EVENT AND CLK='1') THEN
COUNT <= NEW_COUNT;
END IF;
END PROCESS;
END PCM3006_architecture;
tmp_test, count and new_count are removed after compilation.
