11 years agoQuartus II: Reading back programmed file from chip?
I have lost the original design for a project and at least need to read back the data programmed into my EPCS1SI8 part and save it. Is this possible and what option do I select in Quartus II?
11 years agoThanks, I'll give that a shot tomorrow. Yeah, I would like to recover the source but right now I need to get another board up and running, so if I can capture the data and save it that will be a good start.
That link you provided mentioned that the data would have to be captured/saved as a .jic file instead of the original .pof Not familiar with the .jic --- Quote Start --- Hi, I never tried, but the "examine" feature of the Quartus programmer should be able to do that: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd08192010_758.html. There also seems to be another thread about this topic: http://www.alteraforum.com/forum/showthread.php?t=42587 However, this will of course only give you back the data stream, no source files (VHDL/Verilog). Best regards, GooGooCluster --- Quote End ---
