8 years agoQuartus II quits unexpectedly compiling w/ .stp file, but compiles fine without it
Hi, As the title states, my design can compile just fine if I remove the .stp file from the project. I want to test the design running on the board before I started connecting to other modules....
8 years agoThanks for the tips guys. I was able to fix the problem by creating an identical but new project. I think this may be due to device/license changing after project conception. When I made a new project with the license I needed from the start, everything worked fine.
