8 years agoQuartus II quits unexpectedly compiling w/ .stp file, but compiles fine without it
Hi, As the title states, my design can compile just fine if I remove the .stp file from the project. I want to test the design running on the board before I started connecting to other modules....
8 years agoI have internal error with 17.1 and 16.0 (but in other file). It was because in Signaltap were added signals from chain of triggers, that can automaticaly replace with shift register. Without stp no errors, with internal error. When i turn of "Auto Shift Register Replacement" in Compiler Settings -> Advanced Settings (Syntesis), i have no errors. Check this option or others replacement options.
