8 years agoQuartus II quits unexpectedly compiling w/ .stp file, but compiles fine without it
Hi, As the title states, my design can compile just fine if I remove the .stp file from the project. I want to test the design running on the board before I started connecting to other modules....
8 years agoThis happens occasionally. Try deleting the db folders to start a clean compilation. If the problem continues, there's probably a specific problem in your design, or you have revealed a Quartus bug.
