9 years agoQuartus II Programmer - Command Line
Hi, Using the Quartus II Programmer command line (quartus_pgm app) to program a serial flash device using the USB ByteBlaster and want to first erase the full flash device, so planning to use -era...
9 years agoI'd hope it overrides any specifics the programmer gleans from the .jic file. The help on is certainly suggests so:
--- Quote Start --- Option: --erase_all Unified flash programmer option Erase the entire flash before/instead of programming it. --- Quote End --- The .jic file contains details of the FLASH device's sector size and count. The programmer isn't going to know that any other way, which implies it does not use a device bulk erase command, but erases it sector by sector. Shame if that's the case. Cheers, Alex
