9 years agoQuartus II Programmer - Command Line
Hi, Using the Quartus II Programmer command line (quartus_pgm app) to program a serial flash device using the USB ByteBlaster and want to first erase the full flash device, so planning to use -era...
9 years agoNo luck with 'quartus_pgm -c usb-blaster -m JTAG -erase_all', gives an error
When a JTAG Indirect Configuration (.jic) file is assigned to the flash device in the Quartus II programmer, only the region of the flash that contains data in the .jic file is erased. Presume when using say Method 1 or 2 and specifying the .jic file, the -erase_all option overrides and erases the full flash device? Thanks Bill
