9 years agoQuartus II Programmer - Command Line
Hi, Using the Quartus II Programmer command line (quartus_pgm app) to program a serial flash device using the USB ByteBlaster and want to first erase the full flash device, so planning to use -era...
9 years agoI, perhaps naively, assumed you could use
quartus_pgm -c usb-blaster -m JTAG -erase_all Yes, if you specify -o you will need to specify a file. If the above doesn't work (I've no suitable hardware in front of me to try it) then you probably already have the simplest option. Cheers, Alex
