AGofs
5 years agoQuartus II Prime(18.1) Lite sticking during Analysis&Synthesis
Hi everyone,
I've worked with Quartus II Prime(18.1) Lite without any problem until yesterday. Now, the SW has stuck at Analysis&Synthesis stage for 5-6 minutes and then I get an attached message....
sstrell
5 years agoDepending on your design, analysis & synthesis or other stages of the compiler could take much longer than 5 or 6 minutes, so you should probably wait longer to get results. It's not a license issue, because as you said, Lite doesn't need a license.
If you think it's not just a processing issue, you can try trashing the db and incremental_db folders to recompile the design from scratch.
- AGofs5 years ago
You mean Project->Clean Project?
- RichardT_altera5 years ago
Do you able to compile after Clean Project? Have you try to compile the design in the latest Quartus lite 20.1?
- AGofs5 years ago
No, the problem remains.
I never tried to compile the project with Quartus Lite-20.1.
