15 years agoYes, i would prefer the 11.5" or even the 10" because it's light and small...
The problem is that most of 10" netbooks are limited to 600 pixels in height resolution.... I don't want to run heavy compilations on it, the method of work should be that the compilation runs desctop a server in the office, the only thing the netbook shoud do is to download the sof and stp files and operate FPGA download and debug by the signal tap... The big question is what is this "Windows7 Starter"? is it good enough or i need at least the "Home" addition? Are they significant limitations which not allowing to use it? This Alienware M11x really looks like a wild animal and it is 3 times more expensive than the Lenovo IdeaPad U150 with the duo processor and 3G ram... It also less heavy and comes with the Win7 64 bit...
