11 years agoQuartus II keeps crashing on Ubuntu 14.10
Quartus II will start on Ubuntu 14.10. And I've successfully programmed .sof file to Cyclone V. But, if idle for a few minutes, it crashes with the following report: problem details Err...
11 years agoI received an update from Altera support:
--- Quote Start --- The Curl library shipped with Quartus II is not thread-safe and this causes the error you have seen. You can work around this problem by creating an environment variable to set CURLOPT_NOSIGNAL to 1 with the following command: For csh-style shells: setenv CURLOPT_NOSIGNAL 1 For sh-style shells export CURLOPT_NOSIGNAL=1 If you could let me know if this resolves your problem then I can confirm this solution with the factory. --- Quote End --- The suggested workaround did not work for me.
