11 years agoQuartus II keeps crashing on Ubuntu 14.10
Quartus II will start on Ubuntu 14.10. And I've successfully programmed .sof file to Cyclone V. But, if idle for a few minutes, it crashes with the following report: problem details Err...
11 years agoPer Lance's suggestion, I ran Quartus 14.0 all day yesterday on Ubuntu 14.10 -- NO CRASHES. So it does seem the Altera move to Quartus 14.1 is indeed causing the problem on Ubuntu. Thanks for the help Lance.
I'm planning to run and monitor stability of 14.0 base for awhile longer, and then eventually try to install Update 2 to 14.0 andersm, have you sent the crash report to Altera? I did. It would be nice to get this fixed. -- Jeff
