11 years agoQuartus II keeps crashing on Ubuntu 14.10
Quartus II will start on Ubuntu 14.10. And I've successfully programmed .sof file to Cyclone V. But, if idle for a few minutes, it crashes with the following report: problem details Err...
11 years agoThis past weekend I migrated a 14.0 project into 14.1 -- I'm running ubuntu 14.04 (has been very stable with 14.0 tools for me for many months).
I had a few crashes at first -- couldn't complete a compile. I've seen this before, no idea why, but the same sort of crashes initially working with an upgrade (I don't have any specifics stored). It seemed to blow chunks at different stages then for some reason the project will start compiling again (I even archived the project and brought it into 14.1 cleanly, I thought). In any case, I successfully compiled on Centos then moved back to Ubuntu with the project and it seemed to be behaving. Everything seemed to be working fine, but TimeQuest was crashing for me still (both on Centos and Ubuntu after testing). I'm working with the plain cyclone V on the arrow bemicroCV board and the DDR3 pin assignment tcl script doesn't execute successfully on 14.1 for me. This is the second time I tried to get up and running with 14.1 and I've gone back to 14.0.2 or whatever the last was. The two issues I had in the end (TimeQuest crashing and the DDR3 pin assignment script failures) happend on Centos6.5/6.6, I decided to bail. If it were a Ubuntu problem I would have maybe stuck it out a little longer and tried to narrow it down. I'm using the full version, FWIW. Good luck, Lance
