19 years ago
Quartus II is NOT stable itself
From web version v6.0 to v7.1, the software itself crashes over 10 times on my computer every day, usually during synthesis or simulation. That depress me much. The reason make me think it's not my computer's problem is the software seems not well multi-threaded during working, often makes computer freeze for a short while. Does anyone suffer the same problem as me?
    This is what a settings dialog looks like before a crash, software version is QII 7.1sp1.
    It looks like a lack of memory,
    is your machine using virtual memory at that moment ?
    If yes, is there enough virtual memory ?
    Yesterday was not a good day for QII software..
    I've had a lot of internal error (5 different kind) and 3 fatal error too.
    I've opened also the mysupport questions reporting all the errors.
    Cause I've a Core2duo I've told QII to use 2 core and also 1 core but nothing changes..
    If I've not used a lot of IP (that changed a lot in 7.1 versions) I'll return immediatly to v.6.0..
    Here is the list of the Internal errors I've got.
    Have a look also at IntError2 and 5.. they're error in same module and same line.. but.. 2 kind of different errors..
    That discourage me a lot..
    Hi Darkwave -
    You might want to try running a RAM hardware diagnostic. You have found a completely incredible number of unique errors, mostly related to memory allocation / corrupt memory. One of my coworkers had that happen, turned out he had a bad DIMM.
    I've thought the same and today my ex pc was given to informatic systems to check.
    I hope that it depends by ram else I'll be in trouble here at work if I cannot compile and continue to work.
