Quartus ii internal error
Trying to run a waveform which has previously ran before. I did not modify anything and had other waveforms run as well. Here is the error I am receiving:
*** Fatal Error: Access Violation at 0X00007FFA970B5173
Module: qwedt.exe
Stack Trace:
0x15172: VDB_COMPRESSION_GENERATOR::reset_compares + 0x12
0x1ea74: VDB_COMPRESSION_GENERATOR::reset + 0x14
0x4da17: VDB_CHANNEL::set_root + 0x27
0x76e41: VDB_SCF_READER::create_events + 0x5a1
0x787a4: vdb_parser_yyparse + 0xf94
0x7af55: VDB_SCF_READER::sca_read_scf_v2 + 0xa85
0x7d333: VDB_SCF_READER::read_scf + 0x443
0x7feb8: VDB_DATA::read_from_disk + 0x518
0x2bfba: edt_wedtq_create_frame_wnd + 0x1d0a
0x2ae37: edt_wedtq_create_frame_wnd + 0xb87
0x75dc: QUI_APP::init_instance + 0x46c
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0x17033: BaseThreadInitThunk + 0x13
0x52650: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
If anyone could tell me how to fix this itd be much appreciated!
- SyafieqS
nonya,
Does this happen during fitting?
How does you are able to pass the flow previously?
Can you try to delete the qdb and rerun the compilation and see if it works?
- SyafieqS
Hey nonya,
May I know if there is any update?
Can you try to compile it in latest Quartus version of the device and see if it able to pass the flow?
