15 years ago
Quartus II internal error
Hi while using Quartus 9.0 i have faced the following internal error.
internal error: sub-system: med, file: /quartus/edt/med/med_doc.cpp, line: 346
m_number_of_words != 0
stack trace:
0x15daf : _dllmain@12 + 0x348f (edt_med)
0x37d8a : afc_editor_template::open_document_file + 0x35a (gcl_afc)
0x460b5 : afc_template_manager::open_document_file + 0x7d5 (gcl_afc)
end-trace
the Quartus II crashes as soon as we cancel the window. The error arrives when I try to read the contents of the embedded memory at a breakpoint in the simulation time.using processing> simulation debug > embedded memory
I used to do the same in Quartus 8.0 but there was no such issues involved.Is it related to some settings in the software or a bug in the software itself.
Is there any solution to this problem???
Please help!!!
1 Reply
    Have you tried upgrading to quartus 9.1 or 10? If you are desparate for the simulator, you may have to drop back down to 8 as Altera no longer support it - they want you to use modelsim instead.
