Quartus II, Icons too small and whole program seems 'shrunk'?
Can you try to update the driver as step below:
Step 1. Find the display driver under the Display adapters you used.
Step 2. Right-click on that graphics driver.
Step 3. Select Update.
Then Device Manager will perform the updates. Remember to restart your computer after the installation completes.
- PMatt105 years ago
I just installed Quartus Prime Version 20.1.1 Build 720 11/11/2020 SJ Lite Edition and I am having a similar issue. Both the icon size (too small) and font size (too small or too large) are messed up out of the box for me. Notice in the background of the design the font on the counter object is huge, where as the text on the IP window is soo tiny I can't read it with a 24inch monitor. Similarly all the icons too small. Is there an easy fix for this?
Sincerely, Paul.
- Kai395 years ago
I have the same issue. Did you solve it?
- bclemens4 years ago
See this link from our friends at UCDavis: https://www.ece.ucdavis.edu/~bbaas/18/lab/Quartus_Display_Fix.pdf
