10 years agoQuartus II generates empty tdf file, then fails
Hi, when I try to synthesize my design in Quartus II 15.0 the process fails with the error "Text Design File must contain a Subdesign and Logic Section". The file name is cmpr_xxx.tdf where...
10 years agoDear Alex
thanks for your message. After repeatedly deleting and regenerating some of the auto-generated files the design compiled. Unfortunately, I could not reproduce what exact step caused the compilation process to fail. I will keep your suggestion in mind in case the problem occurs again. Regards, David
