10 years agoQuartus II generates empty tdf file, then fails
Hi, when I try to synthesize my design in Quartus II 15.0 the process fails with the error "Text Design File must contain a Subdesign and Logic Section". The file name is cmpr_xxx.tdf where...
10 years agoIf you're still having problems...
Copy 3 files - .qpf, .qsf & .qsys - to a new directory and open the Quartus project there. Open Qsys and the .qsys file. Generate HDL. Once completed, try running the project through Quartus. If that still fails then I suggest you post those three files here. Cheers, Alex
