10 years agoQuartus II generates empty tdf file, then fails
Hi, when I try to synthesize my design in Quartus II 15.0 the process fails with the error "Text Design File must contain a Subdesign and Logic Section". The file name is cmpr_xxx.tdf where...
10 years ago --- Quote Start --- So, your Qsys system is the only entity in your design and is your top level? What file(s) have you added to your Quartus project? --- Quote End --- Basically, yes. It's a design for Cyclone V so there is some additonal peripheral stuff for the hard processor system. --- Quote Start --- You mention the "db" folders - you shouldn't be digging around in there. These are temporary files that Quartus uses/creates. They never contain design source that you need to add to your Quartus project. --- Quote End --- Ususally, I leave this folder alone. But the error orginiates from there: it contains the empty AHDL file. I certainly haven't added this file manually, but it is generated by Quartus.
