Quartus II Fatal error : Stack Overflow
I keep getting this error message on a specific design and basically I don't know where it's coming from. I have tested on 2 separate PCs, one with Windows 7 and the other with Windows 10. I have also tested with versions 17.0 and 17.1 (Lite edition) on both PCs, both with latest updates installed. Below is the report preview. If anyone can help I'd appreciate it greatly.
Thanks!
Problem Details
Error:
*** Fatal Error: Stack Overflow
Module: quartus_map.exe
Stack Trace:
0xf170: scalable_malloc + 0x30 (tbbmalloc) at d:\sj\nightly\17.1std\590\w64\acds\quartus\extlibs 64\tbb\tbb42_20131118oss_altera\src\tbbmalloc\fron tend.cpp:2752
0x107a: operator_new + 0xa (tbbmalloc_proxy) at d:\sj\nightly\17.1std\590\w64\acds\quartus\extlibs 64\tbb\tbb42_20131118oss_altera\src\tbbmalloc\prox y.cpp:350
0x26358: std::_List_alloc<0,std::_List_base_types<STA_CLOCK _TREE_NODE * __ptr64,std::allocator<STA_CLOCK_TREE_NODE * __ptr64> > >::_Buynode0 + 0x28 (TSM_STA)
0x2630a: std::_List_buy<STA_TQ1_PATH_ELEMENT * __ptr64,std::allocator<STA_TQ1_PATH_ELEMENT * __ptr64> >::_Buynode<STA_TQ1_PATH_ELEMENT * __ptr64 const & __ptr64> + 0x1a (TSM_STA)
0x4d93c: std::list<TDB_NODE * __ptr64,std::allocator<TDB_NODE * __ptr64> >::_Insert<TDB_NODE * __ptr64 const & __ptr64> + 0x20 (TSM_STA)
0xfe45c: STA_SCC_MGR::get_scc_from_topological_sorted_list + 0xb05fc (TSM_STA)
0xfe513: STA_SCC_MGR::get_scc_from_topological_sorted_list + 0xb06b3 (TSM_STA)
End-trace
Executable: quartus_map
Comment:
None
System Information
Platform: windows64
OS name: Windows 7
OS version: 6.1
Quartus Prime Information
Address bits: 64
Version: 17.1.0
Build: 590
Edition: Lite Edition
Try trashing the db and incremental_db folders and recompiling.
After spending 3 days trying to understand what it is that Quartus doesn't like, I found out that a part of the code that was running unclocked was causing the issue. I converted it to clocked logic and it worked. But I have no idea why.
if you can isolate the problem to a small project with just that part of the code that still makes Quartus crash, you should report it to Altera. Hopefully they can fix the bug for a future release.
The problem is that this part of the code works OK when isolated, it's when it's integrated into the project that generates the problem!
