16 years agoQuartus II: Error(10777)
Hello, I'm getting an error: --- Quote Start --- Error (10777): VHDL error at part1.vhd(47): expected an architecture identifier in index --- Quote End --- and when I highlight thi...
16 years agoHi, The issue is that Quartus II is seeing your code as an array operation rather than as a component instance as there is no "port map" string.
cnt16 : TFFcounter16bit(SW1, KEY0, SW0, Qout); Try altering your syntax to: cnt16 : TFFcounter16bit port map(SW1, KEY0, SW0, Qout); This will also need to be done for the instances of HEX: seg0 : HEX port map (Qout(3 downto 0), HEX0);
