14 years agoQuartus II crashes
Hi I have Quartus II 11.1 sp1. When I open this and click on New Project Wizard, it crashes. No errors no problems and no explanations (as far as I can see). What should I do. I would downloa...
14 years agounfortunately trying a reinstall is going to be the first step
if you are using the web-based tool, configure it so it doesn't delete the install files after it finishes so you can try another reinstall if necessary
