13 years agoQuartus II compatibility with Windows 8
Hello all,
I am an amateur programmer who has recently started learning VHDL. I have downloaded and installed the Quatus II Free Web Edition from Altera's website. Just for starters I tried to implement and simulate a simple Half Adder. The code compiled without any issues however, when I run a Functional Simulation on the code in order to obtain a waveform diagram, a small window opens and closes immediately and there is no change to the output line. However, when run on a windows 7 machine, it worked fine. Is there some compatibility issue of Quartus 2 with windows 8? Or are there any particular settings to be tweaked? Any help is highly appreciated. My apologies if I sound too much like a novice. Thanks in advance,4 Replies
Wich software do you use for simulation?
IIRC, the current Quartus II version is still not "OFFICIALLY" compatible with Windows 8.
if you're using ModelSim-Altera Starter Edition, see if you can launch it stand alone
--- Quote Start --- if you're using ModelSim-Altera Starter Edition, see if you can launch it stand alone --- Quote End --- I am also having windows 8.1 incompatiblity issues, even though I'm on Windows 10. "WARNING: Detected Windows 8.1 incompatibility.There is a Cygwin incompatibility with Windows 8.1 that must be fixed before using the Monitor Program. Please visit http://www.altera.com/education/univ/software/quartus2/unv-quartus2.htmlfor information on fixing this issue." Unfortunately the url does not exist. Suggestions?
