16 years agoQuartus II Assembler Error
I have a working Quartus II project with a NIOS II CPU. Due to some issues of the custom board concerning the JTAG chain, I cant use the USB Blaster to upload the software to the board. Therefore I included the generated onchip_mem.hex in the SOPC builder to compile the software into the design. While running the assambler I get the following error: --- Quote Start --- Internal Error: Sub-system: ASM, File: /quartus/comp/asm/asm_lab.cpp, Line: 1979 this->jiggle_signal_into_cache(signal) Stack Trace: 0x1ea066: asm_assemble + 0x37dd (comp_asm) 0x1e9579: asm_assemble + 0x2cf0 (comp_asm) 0x1e8511: asm_assemble + 0x1c88 (comp_asm) 0x1e6ce9: asm_assemble + 0x460 (comp_asm) 0xd4e8: qexe_get_command_line + 0x7a8 (comp_qexe) 0xfd58: qexe_process_cmdline_arguments + 0x3f8 (comp_qexe) 0x25056: GEN_PROFILE_BINS::initialize + 0x216 (CCL_GEN) 0xfdee: qexe_standard_main + 0x4e (comp_qexe) End-trace Quartus II Version 9.1 Build 222 10/21/2009 SJ Full Version --- Quote End --- Does anyone have a solution or any suggestions ? Thanks in advance .. ! Alex
