--- Quote Start ---
The releases are usually here:
ftp://ftp.altera.com/outgoing/release/ However, 11.1sp1 does not appear to be there.
Try installing an earlier version and see if that helps. I think that once you have the driver working, it won't get broken by installing 11.1sp2, since Windows will already have the driver installed (so you won't get the new hardware detected dialog when you plug in the USB-Blaster).
Cheers,
Dave
--- Quote End ---
Thank you so much Dave,
I dowloaded Quartus WE 9.1 and my USB Blaster was seen by it.
I went back to 11.1sp2 and it still cannot see the USB Blaster. i really believe there is a BUG in 11.1sp2
