17 years ago --- Quote Start --- It may be the case, that the JTAG loaded configuration has been removed by a reconfiguration attempt in-between, e. g. by some hardware activating NCONFIG. Sometimes, tt may be necessary to check halt on-chip configuration controller in Tools - Options - Programmer. --- Quote End --- It looks like that was the problem - the NCONFIG pin, though pulled high, is connected to a voltage monitor. I suppose it was tripping after the SFL was loaded but before the PROM was loaded. Thanks for your help.
