11 years agoQuartus II Analysis and Synthesis Issues
I have a strange issue with some code I'm working with. I received a Quartus project from TI that should, supposedly, work out of the box. In fact, on the machine running Quartus 2 v13, the code comp...
11 years agoWith your project open, go to 'Assignments' -> 'Settings...'. In the left pane, under 'Compiler Settings', select 'Verilog HDL Input'. Then, in the right pane, you can choose the verilog version.
Cheers, Alex
