11 years agoQuartus II Analysis and Synthesis Issues
I have a strange issue with some code I'm working with. I received a Quartus project from TI that should, supposedly, work out of the box. In fact, on the machine running Quartus 2 v13, the code comp...
11 years ago --- Quote Start --- I can cause the Quartus to generate similar errors (and a lot more - can I assume you've just pasted the first couple into your post?) by changing the compiler settings Verilog version to Verilog-1995. You might check that, although that is part of the project settings and not your installation. --- Quote End --- Can you perhaps instruct me on how to change compiler? Perhaps I can simply make that change and have it work for my purposes. I *am not* a Quartus or even FPGA guru. --- Quote Start --- A long shot but licensing issues often show up in strange ways. You might want to check that. Other than that re-installing v14 doesn't take long although, again, I'm not sure I'd necessarily expect much from that. Or v14 on another machine...? --- Quote End --- If nothing else works I'll certainly try this, my only concern is that this *is* a fresh install, and I'd hate to have the same issue keep coming back! Thanks again for your help!
